A set of T6 H7s, for repair or for spares.
'E' revision, so needs the DRL holder replacing and wiring in, as per the thread:
www.t6forum.com
The RHS needs the holder replacing; the LHS works but probably needs fixing, there was an intermittent 'bulb out' warning light before I took them out.
£50 collected (Stockport or Trafford Park); they are in separate (very large) boxes, if you want them posted I will do so at cost and get a price.
Various DRL bulbs available, an OEM on the LHS and a MARUTA on the RHS, with spares of the MARUTA and probably some LUMRO as well.
RHS
Some scratching on the lower part (not my doing, was like that when I bought them!). Never really bothered me. NO MAIN BULB COVER OR CLIP (see photo).
LHS
NO BULB COVER but the clip is in place.
H7 Headlamp - W21W DRL Bulb Issue. Be Aware
I'd been having an intermittent fault with the off side DRL for a while. As soon as I put my fingers on the bulb holder, it would turn back on for a short time. However, eventually it packed up altogether. So I removed it and discovered this.... The contacts were blackened and the plastic...
RHS
LHS
