Yep, what would you like to know?Has anyone bought the T6 Tailgate LED rear lights with dynamic indicator (T6.1 style) sold by Travelin Lite?
do they need coding and was it straight forward swap when changing to LEDs?Yep, what would you like to know?
Thanks. Looks like I've paid quite a mark up in price over the last two years! Your purchase £165 mine, £296 with 10% discount!This was mine...
T6 [Guide] To T6.1 BARN-DOOR TAIL-LAMP UPGRADE -- How I Done It --
T6.1 REAR LIGHTS UPGRADE -- How I Done It -- T6.1 REAR LIGHT UPGRADE GENUINE VW 03-19 (TWIN REAR DOOR) This popped up on the Travelin-lite FB feed, the price looked good as did the lights, so i though i would give it a go =] the FB link took me to the website above, this is what they...www.t6forum.com
T6.1 LED sequential - REAR LIGHTS UPGRADE (Barn Doors) -- How I Done It --
T6.1 LED - REAR LIGHTS UPGRADE (Barn Doors) -- How I Done It -- Its that time again . . . . Rear light cluster upgrades. ++++ This time with the transporterhq.co.uk pre-made LED T6.1 copy setup. These units come with sequential indicators and a FULL LED setup. this is what the site...www.t6forum.com
I had factory halogens and I didn’t have to code anything very straight forward plug and playdo they need coding and was it straight forward swap when changing to LEDs?
I think it's these ones?Does anyone have a video of the sequential indicators working?
Thanks for your replyAs all lamps in one of the units are not responding and you have made all of the connections, assuming that the pins/wires have been connected up to the correct pins then I would look at the new Earth connection in the first instance.
Good luck getting it sorted, it will be worth it.
All done now with some daylight and dry weather I have now got it done , and yes it was definitely worth itThanks for your reply
that was my first thought, I added a temporary link from the side that work, nothing! Then I cut the Earth to the working light, still nothing. Now with only the one light connected and still not working it can’t be current draw, everything on that side doesn’t work so I can’t see a fuse being the issue. On the bench it works perfectly ????? I’m sure it’s something simple that I’ve overlooked, it’s dark and wet when I get home at the moment so hopefully over the weekend I might be able to get my head around it .
