Just tried mine and its turn to 0 push in and turn to the right then pull out
2017 T6 if that makes z difference
Peatey, any chance you can post photos of where the clips are on switch when removed? not coming out the press in pull out way, so need to try and locate clips to pull it out another way :/Just tried mine and its turn to 0 push in and turn to the right then pull out
Do these help?
Try holding the outer part of the switch in, whilst you turn the rotating part to unlock the tabs. If you turn and pull at the same time, there can be too much resistance for the tabs to release.
Do I press outer rim?
ThankyouTurn knob to off position, push in and turn klockwise, pull out. All by touching the knob only.
Remove the headlight switch, so video link below for demo:
Dropbox - Headlight switch removal.mov
Disconnect the wiring from the light switch, and remove the screw tonthe rear at the bottom of the housing.
Yes, it is the same procedure.Really appreciate the help
My switch doesn’t have Auto is it still same procedure
If so I will try again tomorrow
