Heated mirror passenger side not working
DugVan
Passenger side mirror not heating 2019 T6, am I right in thinking it can't be the fuse because drivers is ok. Have no diagnostic stuff wouldn't know where to start. Purchased from Salop Vans November, still under 3 months warranty but it is a long way away.
Contacted Salop Vans waiting on reply.
If you plug your (presumably known good) drivers glass into you passenger side electrics, does it heat up? Could be element in the passenger glass.
Thanks that's a great idea, just a bit worried I might break something. Not sure if I am confident enough to try it. It could be an easy fix or easy to rule stuff out. Will wait until weather is a bit better, maybe by then I will have plucked up the courage.
I’ve just replaced the glass on my drivers side as it was no longer heating. £15 and all of 2 mins to replace and it’s fixed.
Glass is better than the OE I took off as it contains the split section to improve vision.
Sourced from here if that helps
Thanks very much at that price will order one and give it a go
This is less than helpful. Mine’s a 2016. :D
The mirrors changed so I'm guessing 2010 is t5.1 type mirrors and the later option is t6 type ?
I am of course completely guessing cuz I can't tell the difference to look at :oops::whistle:
