T6 Heated Seats Circuit Circuit Diagrams Please check the history/updates tab, first release is for early T6s from 2015, second release is for vehicles from June 2016 onwards VIP Membership is required to download this document
Its fitted into the rear of seat base heat pad. You can either replace the whole pad or just temp sensor by inserting new one as far as you can between the fabric,pad and cushion, but also would need to repin the two wires from the old one from plug under the base to bypass the damaged one.
It's also possible you have a wire break, so check the wiring. I believe it's a single 4 pin connector under the seat and a 10 pin into the loom, a loose connector seems less likely if the heating wires themselves are working.
