SteveCole
Hi all,
This is my 1st post to the forum, and I was hoping this would be a handy how to but instead I am after a helping hand. I have had my T6 Kombi for a few months now and I have decided to retro fit the genuine heated seats, in the summer Not seen a full how to so I thought I could contribute however so far its not been going well. I have fitted the genuine seat pads, control module and aircon control. The bit that I am struggling with is the Kufatec wiring instructions! They make very little sense and as access is so limited I am really struggling.
1st off it says I need to connect into the fuse box (SC25) and install an appropriate fuse, SC25 already has a 10A fuse and from what I can see this powers the heated washers and rear wiper?? However SC27 looks like it should be for the original heated seats (which is an empty slot) Should I be tapping into this or am I meant to be putting a 90 degree Add A Circuit fuse holder into 25?
The next issue is cable K1.86 to a relay? Apparently is goes to designation J29 and is an X-Contact (relief relay) It's called cable K1.86 as it goes to terminal 86 and pin 1 of the Relay. All sounds well and good but I have no idea which relay it is? I have two above my BCM module, (646) + (524) when I emailed Kufatec they said it should be a relay that is imprinted 449? I have double checked and I definitely have the right loom (according to them) however Kufatec didn't take any pictures during the instal so I am finding it very difficult.
Next it is saying about connecting cables A54 and A35 into plug A of the BCM module to pins 54 and 35. when I tried to fit it, it already has a pin in 54! what is going on here, it is so frustrating! I can add photo's if this might help someone? I just didn't want to confuse matters.
Thanks in advance
Steve
Thanks in advance
Steve
