Snakey732004
Hi, my 2016 VW transporter T6 seems to only blow cold air when the dial is set to the coldest setting. Soon as you move off the coldest setting it blows hot air. Anyone else seen this before and can help?
Have you got anymore info on this - ie was it the sensor that is built in to the unit, or elsewhere? Did they replace the climate unit with another one?I've literally just had this repaired at VW under warranty for the exact same fault - it was a temperature sensor that was faulty
I understand it to be the sensor on the dash. At first they were talking about a whole new heaterbox and having the dash out, but eventually they pinpointed it to the one sensor that was giving a wrong reading. It took them three weeks in the end to locate it thoughHave you got anymore info on this - ie was it the sensor that is built in to the unit, or elsewhere? Did they replace the climate unit with another one?
Interesting. Cheers.I understand it to be the sensor on the dash. At first they were talking about a whole new heaterbox and having the dash out, but eventually they pinpointed it to the one sensor that was giving a wrong reading. It took them three weeks in the end to locate it though
Mine does, yes. Haven’t got ODIS - I wonder if VCDS has this reset test plan, too - as I know someone local with a lead.Does the vehicle have A/c? Or is it manual adjustment on the dials?
Theres a reset test plan, for outside / inside temperatures relating to the A/c system on ODIS. I'm not sure too many people / techs know about it.
I've personally seen a couple of similar issues relating to temp readings, which stops the A/C activating correctly.
May be worth the question to your local dealer.?
I would imagine so, I haven't personally looked into it with VCDS.Mine does, yes. Haven’t got ODIS - I wonder if VCDS has this reset test plan, too - as I know someone local with a lead.
@Snakey732004 do you have A/C?
It does yes. Not sure why it blows cold if it is turned all the way down soon as I move off the lowest setting it blows hot. Tried all the settings and directions.Mine does, yes. Haven’t got ODIS - I wonder if VCDS has this reset test plan, too - as I know someone local with a lead.
May not have articulated my response apologies. Now it's getting warmer I like to have a nice cold cab. The only time I can get it cold is by turning the heat all the way down to it's lowest setting. If I'm too cold I turn it up...but in this case I only just need to move the dial slightly off the lowest setting and it starts blowing hot air and doesn't stop until it's uncomfortably hot. It does sound like a thermostat issue as I do get cold air from the A/C but again at it's lowest setting. I have a heated front screen so not needing to have it pointed at the screen. Is there a thermistor that I could change or something out there that can suggest how to go about fault finding the issue?i might be wrong... but the dial is a thermostat control but mid position mine says 22 above the knob which is just comfortable temp to sit in..
you might have a problem with yours.......
so temps below that would bring on the heating its a type of climate control not an old fashioned heater...
on a warm day you might find it turns the cooling on with the dial up a little more
if the air con is on it will allow a little warm air into to mix . it does not turn the air con on /off.
i don't ever adjust mine it will warm up slowly defrosting the screen .. a bit of patience might help.
Tuning the heat up from a cold start wont warm the van up any quicker lol.... or crack your screen
@ 22 on the dial if i drive to work with the window open and its cold outside mine goes into heating.....
i do turn it right down then put the A/C on....... but i was a air conditioning engineer for 20 years
Mine hasn’t always been like this so I’d definitely say it’s a defect. I’d normally leave it bang on 12 o’clock like @Mud Digger does but now it’s red hot if I do.Mine has been like that since new, I only move the dial a degree or so from cold at a time to have any control. I've learnt to live with it like that but it is a pain. It is much like adjusting the output on a Webasto diesel heater with a rheostat, move it an extremely small amount at a time.
