Put the van in for a heater support pump error with a specialist.
It has the following errors (starts off supply voltage eventually throws an EML).
Put it into a ‘specialist’, and asked them to check the wiring and supply voltage first.
They called and asked if I wanted them to change the pump, I told them to again, make sure they look at the plug and wiring first.
They called me later to say all done, so I picked it up and it still had the error in the ECU, I figured they forgot to clear it, so I cleared it. I use the vab this weekend and guess what, same error comes back
So must be a wire or connector… thats £300 I may aswell set fire to and now back to square one - me messing around with the wiring like I didn’t want to and didn’t have time to do, hence giving it to a garage so I’d have leas stress…….
I give up.
Anyhow, can anyone please help to provide any hints on where to look first. I assume I’m going to need to pull the airbox and inlet pipe to get to the connector, remove the D clip and get a volt meter and run output tests first. But if anyone has any diagrams or info or tips on common issues / where wiring goes etc would be appreciated.
A rather fed up and pissed of T6 owner…
I give up.
