[HELD] Inovit Torque 20" gloss black staggered with tyres
huw169
Black 199 Shuttle
Hi All
Was keen to keep these as i love the look on my van, but i'm going in a different direction and just can't have this much cost sitting in the garage.
Wheels are INOVIT Torque 20" as per title.
Fronts are 8.5 wide with ET35 and have brand new (100 miles on) Nankang AS 2+ tyres in 245/45.
Rears are 10" wide ET40 and have Nankang AS 1 tyres that are about half way worn in 275/40.
The wheels are load rated to 875kg each and the tyres are all 103 or higher so all suitable for T32.
They are freshly refurbished due to the tyre fitter scratching the rims when the two new front tyres were fitted. They came out so good, I also had the rears done. Never been curbed as I'm really careful, but they are all as new now as they have not been back on the van since the refurb.
They are all straight and balanced with no cracks ready to go straight on.
The tyres have the same rolling radius front to rear.
The wear on the rears is perfectly even across the tread as I had the van 4 wheel aligned as soon as it was lowered and the wheels fitted.
The wheels will come with spigot rings for VW fitting, the correct black wheel bolts and a set of black locking bolts.
My van is lowered about 65mm, so if you are lower then I would suggest these wheels are not suitable as it will start to scuff on heavy compression, but at 65 mm and up its all good. No rub lock to lock, and plenty of room at the rear so you can load the van up.
To buy all this new would be about £1700 - 1800.
I'm after £1300 ovno
Wheels are based in Portsmouth
After my last experience with posting something for sale, I'm not doing that so please don't ask.
Cash or bank transfer on collection only.
I'v added some photos of how they sat on my van, and the post refurb close up wheel photo's off the van.
Got my new banded steels on now so these need to go.
£1100 Ono.
I could get them to Swindon if that helps, but wouldn’t be immediately.
