Hi, I have a T6.1 2022 Kombi SWB fitted with a Jerba Campervans pop top and no awning rails.
I have a Fiamma F45s awning and the bracket kit that bolts to the original roof bar mounting points. I have done a trial mock up and there appears to be clearance to use the original fixing point and brackets at the front but the rear is a no go because of the pop top hinges. I imagine I need to cut the "gutter" part off the bracket and then use riv nuts/bond to hold the back one on?
I tried to look at several at the NEC last month and all the ones I could see that had pop tops on had had the brackets chopped both ends and riv nutted on in a variety of places, some no where near the "support" stickers on the awning box which the manufacturers instructions say should align with the brackets.
So... those of you that have a F45s with a pop top how are yours fixed on and what are the measurements for your brackets from the rear of the van and are the bracket positions actually crucial? bearing in mind the photos of the blue van were from an approved converter!
Original bolt to be picked up for front Fiamma bracket
Fiamma bracket mock up
NEC front bracket cut and shut...at least 6" rearwards from instructions
NEC rear bracket cut and shut... no where near "support" sticker.
