Help with awning rail - which one do I need?
T6ChrisO
AutoCAD engineer
T6 Legend
Hi guys,
I’m looking for a cheap awning rail and come across this from Funky Leisure.
My roof bars are mounted to the pop top, not the van body but wondered if it was still suitable and would the pop top close ok?
My roof/van
Thank you
For £2.99 they'll post you a short sample length so you can check clearances for yourself
I suspect the challenge will not be the profile but the length.
Cheers, I didn’t see that. Extended C rail option ordered
that rail may pop up too much and foul the pop-top when closed. . .
id look at a concealed C-rail.
like this one I've fitted. . . . it should fit in the gap below the closed pop-top.
and fitting from here:
Ok, ordered all three samples :)
If you go for an exposed (reimo or vamoose) rail, they are quite slim and look ok. The additional advantage being eliminating water drips above the passenger and slide door in normal use.
