Hi From Newbie Cpl Of Questions
SimonCol
Hi all brand newbie here and now the proud owner of a T5 Leisuredrive Crusader.
I have a green switch on the dash which is live though no idea what it’s for.
Also I have 6 holes drilled at bottom of windows on each side is there something to attach here? Any help appreciated.IMG_1419.jpeg
Any evidence that it's ever had beacons or strobes on the roof or in the grille?
Welcome.
The holes in the glass are Drain holes for the sliding window.
They don't have any other purpose I'm afraid.
Im not sure on the switch. Does it do anything when switched ? light up etc
Hi Thanks for your help on the drain holes makes sense good job i didnt fill them :)
The switch does light up when turned on.
thanks
So there's definitely power to the switch. It could be so many things, even a switch to power the radio from leisure battery? rear lighting ?
It's definitely aftermarket so hard to say without further investigation.
Maybe in time it will come apparent. But let us know when you find out
Recent regulations say that you should have an (annoying) light on the dashboard when the diesel heater is switched on. Could that apply to you?
Cheers will do
Welcome to the forum and Team Leisuredrive!
