I have what appears to be a central locking issue. It occurs mostly with key fob use... so I currently lock and unlock manually.
Movement of slightest amount may play a role in activating the lock and unlock lock and unlock sequence. Although the alarm doesn't make a noise, everything else looks as though the alarm is activated - hazards etc .. except the alarm noise. As I say, windows go down.
I am unable to lock from driver's door inside, and unable to sleep inside currently.
Has anyone any familiarity with some of this. Both key fobs work - but it is when I use key fobs externally, the problems may start too.
