I think you have got a pannel van ply kit .So got this ply line and see it is much bigger than the standard panel. The hidden clips would surely not reach the holes in the van. Also this requires the panel to be bent, so surely screws to the van must be the best way to fit this panel. This panel therefore fits further away from the wall and thereby reducing van space. If screwing, what screws would you suggest?
This panel also covers the seat belt post, so holes need cutting in. Plus would the seat belt trim fit over the hole after carpeting?
I started to cut it down, but stopped to rethink.
Any advice?
View attachment 6382 View attachment 6383
4mm is better for side doors and the small seat belt panel ,as 6mm plus carpet looks a bit thick .Did you get to the bottom of the hidden clip issue? I was planning on doing my panels 6mm very shortly but now worried the hidden clips require a thinner ply?
That's exactly what I was getting at. From the outer face and plug after inserting the clips so you have a smooth surface to carpet.@xpfloyd I have pondered getting my router out and routing a 2.2mm depth hole in the 6mm ply and there by making them fit. Might have to go from the outer face of the ply though as from the back would be making the clip length shorter...... unless there are longer ones out there in the market place?
I just used a countersink bit from the face ,the fit perfectly ,I just got a small screwdriver and made sure they were pulled fully through .@xpfloyd I have pondered getting my router out and routing a 2.2mm depth hole in the 6mm ply and there by making them fit. Might have to go from the outer face of the ply though as from the back would be making the clip length shorter...... unless there are longer ones out there in the market place?
I got some fromWhere are you guys buying the clips from?
Thanks. Ordered them from bolt on bits thereI got some from
Bolt on bits ,they have an eBay page
And Harrison's trim supplies .
I can't see them through my carpet ,if you run your finger over you can only just feel themTried the hidden clips with 6mm ply.
9mm hole,
slightly countersunk the back of the panel
Router on the front by 1.2mm ish and slightly off centre.
Looks not too bad. Not sure what ito will look like with the carpet over the top.
The photos show different attempts, but the bottom right clip on the left pic, is the best attempt.
View attachment 6579 View attachment 6580
