Hidden fixing clips 6mm board
Dino
hi.
Does anyone know if a larger clip exists to enable 6mm ply to be used. The regular clips only accommodate 4mm boards.
Cheers Dino.
@Dino ,if you get a countersink drill on the face of the ply ,it is possible to use the hidden clips in 6 mm .
Just make sure it is pulled in all the way round .
Also fit the clips before you carpet the pannel ,then you can see they are in place.
Cheers @carlg . So much to learn.
