I have posted this problem before on T5 forum but I still can’t get to bottom of it was hoping for some assistance here is poss
has anybody experienced these symptoms.
1) high coolant temperature around 110 degrees!!!!
2) fan running after engine turned off.
the only way I can check coolant temp is via a dongle in OBD11 socket (no temp gauge on my van) I appreciate this may not be 100% accurate but I assume the temp is high as fan is running full speed.
It’s been with mechanic had new water pump, timing belt And temp sensor but the symptoms are still the same?? If anybody has had similar it may help me get this sorted
