Just been talking to Lee at Hilo.
Dropped my van off on Monday at the factory in Preston, after a 3 hour drive to get it there. Lee wasn't there so discussed the issues with a lad called Jake. He was aware of
@Deaky's issue having seen his the week before, so when I said it had started leaking his response was "if VanDoc fitted it, I know exactly where I am going to start looking for that particular problem!".
With the roof elevated he instantly spotted that the frame sits too high at the front, meaning it had not been put on properly.
So Lee has confirmed these points now that they have been able to strip it all back a bit. The leaking is definately down to how it has been sealed around the bottom of the fabric. Lee says that the installer is given instructions to grind the paint off the frame to ensure the sealant keys properly. VanDoc had not done this with mine (or Deakys) and so the sealant was now lifting so water was getting in under the fabric. They have also looked at how it could have rubbed to cause the fabric to hole as a result of friction. He says this is due to the J-rail that holds the fabric in place not being trimmed properly (not sure if this is a supply issue or a fitting issue). So they are sorting this out so they don't sit proud, which should then take them away from the point at which the roof closes, meaning it can't rub. As to the holes in the fabric he claims that once they put it all back toegther, due to all of the tweeks, the holes will actually be above the framework, so will not be at all visible or cause any problems.
Fingers crossed I'll be picking it up week Thursday. Will let you know what I think after getting it back.
I did spend some time conversing with Lee about how lots of people were voicing concern over their customer services. I explained that people accept that things go wrong, but not being able to get communication to discuss the issue is what was making Hilo owners very frustrated.
