I’ve had a 72 plate T6.1 PV for a month or so now. I’ve insulated / sound deadened / carpeted, and fitted a 112 Rib bed. Window wise, I’ve done the barn door, sliding door, and opposite sliding door.
I had curtains in my last van, but want blinds in this one. I, along with probably many others, can’t justify Van Shades or Voodoo’s latest offerings.
As such, I’ve taken the plunge and decided to make my own. I don’t have a finished item yet, so if you’re keen to see a finished project, check back in a few weeks.
Ideally I’d have used the same stuff that “Perfect Fit Blinds” are made of, but I couldn’t find a supplier of the components. I’d imagine you could use my dimensions to order some if you wanted.
I’m not making these to sell, but will put all dimensions and material on here for others to use. Until I’ve a finished item, this post will be a development in progress, and any advise it welcome.
I’m basing the design on a SWB 2022 PV with Kamper Glass flush sliding windows. I intend to be able to use the blinds if the windows are open.
Schottis blinds from IKEA. £5 for 100cm w x 180 H
I wanted the openings as large as possible so had a play around with what Screwfix had in stock. (38x25 trunking) This won’t be the final material choice, but was cheap, and very available.
THE BARN DOOR FRAME
The overall dimensions for the barn doors are 580mm wide X 495mm high.
Once fitted they looked like this:
You can see that the ply for the barn doors has been pushed out at the top. I used ply with no window holes and cut a hole in the center which I gradually made larger when I was sure of where the frame would sit. At the moment, the frame is still larger than the opening, but the final piece will have a flush opening.
I’ll cut small pieces of ply and fill the gaps around the outside. Once, carpeted it’ll all look like one piece. I’ll also need to either paint or carpet the part of the ply that’s visible from outside. I’ll use black trunking.
THE BARN DOOR BLIND
The Schottis blinds have adhesive at one end which I’ll use to stick them onto the top of the frame. (Once they are cut down.)
Regarding the bottom of the blind, I want to be able to hold the blind in the open and closed position, and maybe a central position as well. I have an idea for this mechanism, but don’t fancy drawing it on my phone. I’ll try and get it drawn on the laptop.
THE BARN DOOR FRAME
THE BARN DOOR BLIND
