I have spent many hours searching but have not found anything that is made of steel and is easily removable which is why I was asking.I’ve seen lots of DIY examples on the forum - you might need to invest some time in searching.
One of the simplest I remember is carpet covered ply boards on cut to size Ikea screw on table legs. Easy to store when not in use (unlike a frame)
I'm planning on building one using tube clamps and tube. Then will make a collapsible bed base from ply. Hoping to fit this whilst still being able to keep all seats in and make use of my sliding MTB tray with bikes on. I don't own a welder, so these tube clamps will be perfect for me and can dismantle quickly.
Yes me to but motorbike for trackdaysThe two I'm considering is Van King & Forty Winks
The dilemma I have is having these semi assembled and able to carry bikes at the same time.
I need to carry a motorbike so getting to the track and then assemble the bed, looking at a frame on both sides fixed the folding boards that will be kept on the floor then put on the bed when I need the bed, just trying to get some ideasI was considering the same to keeps costs down and to suit personal needs, I've made a few things already using scaffold at home such as my office desk and a breakfast table in our kitchen. I haven't completely given up on the idea yet!
Forty winks, from what I understand is fixed just above the arches so becomes difficult with bikes which is a pity.
Van king is more expensive but can be broken down as @Whitty mentions, they used to sell the frame/boards without the cushions which would have been ideal for us. If this was an option we'd probably buy one.
I initially had a futon strapped to the back of the triple seat, it was a bit cumbersome and heavy but worked very well.
Sorry @Stevef37 for hijacking the thread!
Could you take some pics for me please, want to see how the boards slide in and how the cross beams are attached, this so far looks like the best option for me to modify and make myself so all is removableGoing to modify my Van King so that I can have a 3/4 width bed and storage for bike whilst at events. Plan to get shorter cross members (width of the double seat), then move the left side over and add a couple of extra bars across the bottom. New bit of plywood and then turn the back part of the mattress around. Just need some extra foam for the bit over seat backs. Did the same with the timber set up I did before and worked well.
Hi there, take a look at the video on the Van King. Simple assembly. Two sides that bolt down on to the lashing points, as before these can be left in when bed not required. 3 x cross bars that fix from underneath onto studs and secured with thumb screws. Then slide the wood base into the channels on each side and place mattress on top. Mattress is in 3 sections that zip together.Could you take some pics for me please, want to see how the boards slide in and how the cross beams are attached, this so far looks like the best option for me to modify and make myself so all is removable
