How did you do your laminate floor?
boxer750
Hi
In my van the floor is a ukvanfurniture oak laminate floor (10mm and won't have anything else on top) on top of battens, and sound deadening between the grooves..
Is that enough? I've started seeing vids on you tube of vans having a layer of some kind of sticky foam all over and on larger vans a whole sub floor with hard foam blocks in the floor. Also seeing comments about a vapour barrier, although opinions are divided on this.
I don't have a pop top so wanting to minimise losing headroom.
The walls and ceiling are sound deadened, and insulated
While I'm not so sensitive to the temperature.. am not getting any younger ☹️
Wondering what's 'normal' on a T6?
Pete
I wanted to keep the laminate floor as new so fitted a lino floor on top using double-sided tape. Pleased enough with the finish and only took about an hour.
Before:
After:
