Ok, this might be a bit of a noob question but I don't want to set my car on fire so here we are! I picked up some relays for my latest project and the bloke at the shop tried to convince me that I should use some of these yellow quick connects. I already had a few floating around at home so I didn't buy them, but something just seems a little off here.
None of these quick connects seem to have an amp rating. The cable that went to my aux battery (now DC-DC charger, thanks for the writeup @Delmassive) is something like 10mm and had an 80A fuse and 100A relay, with a cable run length of I guess 2-3m. This is probably going to be about 2m, and needs to handle up to 120A comfortably (it'll have a 120A breaker). It's going to have a 120A Anderson connector which looks far more robust than these little connectors. The point just above the insulation where it flares out is tiny (either side of the hole is about 3mm and about 0.5mm thick so very roughly 3 mm2 cross sectional area) and aluminium, not copper like the connector on the original relay holder. I haven't been able to have a good look at the original connector because it's stuck inside the holder, but I'd expect something a bit beefier. Am I unnecessarily worried here or is there a better option?
Great segue - are the relay holders like the one used by the stock aux battery charging relay available generally (if so, what are they called?) or are they a VW special? I've got a lot of spare slots under both seats I'd prefer to use rather than figuring out an alternative mounting solution. I'd need SPDT rather than SPST like the original one.
datasheet for the relay: https://www.jaycar.com.au/medias/sys_master/images/images/9671127662622/SY4073-dataSheetMain.pdf
