Yeah they do seem pretty cool and also handy to diagnose your own motor. Not a fan of the ongoing subscription though. But I guess you can cancel and resubscribe whenever you need it.You get a month of full functionality for free. (Tweaks, resets etc)
They are defo not going to be as good as main dealers' equipment but will show up errors - very handy for that.
Also to check mileage etc.
It is easy to break some settings with the Carista - at least it was for me. I lost the folding mirrors functionality but was steered in the right direction to get them back again.
Give a chimp a Carista and see what happens.
Judging by some of the tales of woe on here, most official VW service centres are not aware of that yet.The important thing here is they're just tools - none are going to really do a diagnostic for you that's done by the human using the tool.
Back in June 2021 Carista were offering a lifetime subscription for £83.99 but don’t offer it anymore sadly.Yeah they do seem pretty cool and also handy to diagnose your own motor. Not a fan of the ongoing subscription though. But I guess you can cancel and resubscribe whenever you need it.
The only way to tell is to thoroughly clean the engine and gearbox from the top down.Also I've just seen the VHC video and the guy mentions the gearbox slightly damp and then moves on to the tyre tread. They didn't seem to mention this anywhere else. Is this not a concern?
The gearbox oil was just topped up to full 3 weeks ago. If that was leaking they probably would have flagged that up I assume, so not 100% sure. Would oil still be wettish from an oil change 3 weeks ago if it got on those components? They empty it around that area don't they? (I'm guessing by the way because I'm new to these motors)The only way to tell is to thoroughly clean the engine and gearbox from the top down.
If the oil is black it’s most likely the drive end crankshaft seal, is the engine oil level dropping?
If it’s relatively clear oil it’s brake fluid (hydraulic fluid) from the clutch slave cylinder.
Either way it’s a gearbox and clutch out job. Worth considering the mileage and taking the opportunity to renew the clutch, DMF and slave cylinder.
First job is to eliminate other potential leakage / spills.
The gearbox oil change was done at a different main dealer, it's in the paperwork for it.Is this the same van as in your other thread that you are thinking of buying?
What's the worst thing this warning light could mean?
Both the AA a d RAC offer commercial inspection services: https://www.theaa.com/vehicle-inspection/ https://www.rac.co.uk/buying-a-car/vehicle-inspections I've seen these before. Do you think they are more thorough than a full service? Cheerswww.t6forum.com
If so how do you know the gearbox oil was topped up 3 weeks ago? And do you know why?
Have you asked the dealer specifically the question you are asking here, is the gearbox dampness mentioned in the inspection video a concern, maybe in writing if you're concerned about failures should you go ahead with the purchase? At least then if the worst happens you have a written statement of opinion from an actual business that you have some comeback on, not just a thread on an enthusiasts forum?
