My van came with a set of H&R coilovers installed. I'm 99% sure they are the standard drop ones:
I'm not a fan of having a huge drop on these vans but I do really rate the ride and handling with these shocks. So, I wound the coilovers up a bit to get a bit more height at the front. This was especially needed after I installed my new wheels. The pic below shows the wheel/arch with the coils wound up around 2cm from where they were set when I bought the van:
For me, this was still a hair low so I wound up the shocks another 1cm or so. I don't have a pic handy but the ride height now looks spot on to me (with an equal gap all the way around the wheel and a bit more clearance for the front spoiler). Van also drives great. All good.
Only concern I have is whether I've set the van too high for the coilovers? Is that even possible? I think the drop is now right at the minimum limit for the kit and found that the last few 'winds' of the collar met with a lot more resistance as they started to really compress the spring (van was jacked up).
For reference, the center to arch measurement is now ~41.5cm vs stock which I think is about 46-47cm.
I also noticed that the dirt shield thing inside the spring now only just meets the shock body:
Hopefully I'm not committing a major gaff here as I'm really chuffed with how the van looks and drives now.
Cheers.
H&R Coilover Kit for VW Transporter T5 / T6 / T6.1 T32 Clamp Hub - Still Static - Got The Drop
H&R Transporter Fits T5 03/03> Multivan, Transporter, California, LKW inc Facelift ( Type 7HK, 7HKXO,7HM,7HMA,7HC,7HCA,7JO,2WD+4WD ) Lowering T5 Models Front : 80mm Rear : 70mm Fits T6 2015> Multivan, Transporter, California, LKW inc Facelift ( Type 7HC,7HMA,7JO, 2WD+4WD ) Lowering T6...
still-static.com
Cheers.
