Ok so all dependant on how far you want to travel. For T32 we’d recommend the Bilstein B14 Komforts. They work very well, even on 20” wheels, and allow you to lower from 40-70mm. There are other options out there as well, from Eibach, KW to name a couple. Then you have the dseperate shock/spring packages. The market is awash with excellent suspension options now, which is great for the consumer, some might say too much choice. They all give excellent results - some allowing different levels of adjustment.
