I'm thinking about changing my rear seats in my Kombi from 2+1 to 3 single seats.
Has anyone done this or does anyone know what's involved?
I already have the seat belts for the outer seats as mine is a Kombi and I use it as a day van so don't have any intentions to convert it.I have a middle shuttle seat (for row 3) and I can fit this in 3 positions on the second row. If I was converting a van and only needed two rear seats I’d have two middle shuttle seats with integral belts.
Thank you @Paynewright for your help.Yes but only two brackets that basically mirror your current single seat mounts. Middle seats tend to be the expensive ones of the set.
Thats my current set up but when I spin the passenger seat I like to have the single to put my feet on. ( I'm getting old and like my creature comforts)You could just leave your single seat out to give access to the back albeit a bit of a zig zag!
Im wanting to swap my 2+1 rear seats from my current van to new van when it arrives. Didn’t realise the floor pan had those indentations there.I’ve added the 4 extra floor brackets to do this. It was tricky getting under one of the heat shields to do the nuts up and had to drop the exhaust. All done on the drive on its wheels. Your existing kombi 2/1 brackets are all in the right places already!
Here is a picture after I’d drilled the holes after checking 10 times. The divots in the floor pan are the give away!
probably a silly question but as your picture shows is it as easy as using the bracket as a template seated in the indentation to pilot the holes for bolts?
Thanks. Appreciate it. I’ve had quite a few sleepless nights thinking about doing it! I think I’ve seen a thread on here about the procedure underneath.pretty much though you have to drop the fuel / adblue tank. You can use your existing van to make a template.
Another possible stupid question. Apart from taking the seats out of my current van I’d like to leave everything else as is for re-sale. Going to order a new ready to fit 12mm ply floor for new van. What would you say is the best way to mark out the holes needed for the seat brackets to fit through?
I have looked at doing that but it's over 5k and its a bit too posh.You could do the two captains seats in the rear if you fitted caravelle rails to the floor @Lord Mfwic and used single caravelle rears
What is the gap between your two rear seats (at the closest point) ?I had rear seats fitted to my T6.1 panel van in France using this seating system:-
with this flooring:-
I only run the two seats so I can access the rear easy. The rear seats were ordered with the same trim as the front. Its all EU approved (maybe no good for the the UK now!!) and the company made all the paper work changes to register the van as a 5 seater.
I like it, but it wasn't cheap ......
View attachment 82336 View attachment 82337 View attachment 82338
