How to drive in snow?
Gillon Johnstone
Just a quickie,
We have our first be t6 lwb manual shuttle and have no idea how she will behave in the snow with or without snow tyres. Can anyone please share their wisodm, advice and/or experience with the White stuff please and thankyou
I Personally love the challenge of driving in the snow....
Our previous T5.1 was 4Motion and dealt with it no problems at all. . . . =]
But a standard front wheel drive van with heavy load in the rear will always struggle . . . . . especially going up-hill when the front axel is unloaded..
the standard snow/ics driving stsyles apply..
ie:
use high gears to stop the wheels spinning up.
use engine braking as much as possible.
be very gentle with the brakes.
anticipate/expect ice slides and loss of traction so your not surprised by it.
Here are the RAC recommendations, thats worth a quick read.
How to tackle driving in the snow
  • Wear comfortable and dry footwear
  • Accelerate gently, use low revs and change up to a higher gear as quickly as possible
  • Move off in second gear as this will help reduce wheel slip - some cars have a winter mode, which does the same job – so to check whether your car has this function in the vehicle’s handbook
  • Get your speed right and maintain safe stopping distances between you and the car in front, leaving as much as 10 times the normal recommended gap
  • Prepare for an uphill by leaving plenty of room in front so you can maintain a constant speed without the need for changing gear
  • Use a low gear for going downhill and try to avoid braking unless necessary, make sure you leave plenty of space between you and the car in front
  • When approaching a bend, brake before you actually start to turn the steering wheel. If your car does lose grip try not to panic; the key thing is to take your foot off the accelerator and make sure that your wheels are pointing in the direction you want to go in
  • If you do encounter a skid, steer gently into it - for example, if the rear of the car is sliding to the right, steer to the right. Do not take your hands off the steering wheel or stamp your foot on the brakes
  • When driving in heavy snow, make sure that you use your dipped headlights. Relying on daytime running lights is not enough, because they don’t always put lights on the back of your car.
  • If visibility drops below a 100m, put your fog lights on. But remember to turn them off when the visibility improves.
  • If the road has not been gritted, be wary of driving in the wheeltracks or other vehicles as compressed snow is likely to be more icy than fresh snow
  • Controls such as the brakes, as well as the steering, accelerator and even gear changing should be operated smoothly and slowly
  • Sunglasses can help to reduce the glare of low winter sun on the snow
  • Keep your speed down and allow more time to stop and steer
  • Finally, it’s important to think about the environment that you’re driving in, especially microclimates that might appear on the road. These are areas that perhaps the sun hasn’t got to, which could stay icy when the rest of the road has thawed. Bridges are a good example. They’re normally the first to freeze and the last to thaw. So be aware of that when you’re driving in open spaces.
REMEMBER: Make sure you keep your car clean. The salt used to de-ice roads can cause corrosion to your car over time, so it’s worth making a point of cleaning it regularly throughout the winter months.
Below we have a short and informative video outlining all things to consider when driving in the snow to complement the points above.
source: A complete guide to safe driving in the snow | RAC Drive
