I like that flowmeter, would be better if it would auto shut off when it had passed a given volume. I always run the water through the hot water tap when filling, not only to stop element damage but also so you get the volume of water in the tank plus the hot water cylinderI'd wondered about getting a hoselock flowmeter for filling up as otherwise the only way to tell how much is in there is when it overflows!
I use an ordinary garden hose, the same one I use to wash the van, and I have no hangups about drinking it. My own personal view is that these days we're getting so hung up on hygene that our immune systems are becoming redundant and this makes us more prone to infection.
As my old Dad used to say, "You've got t'eyt a peck o' muck afore yer die" - but I'm not a doctor so dont take my advice!
Our family business is a large Boarding Kennels - so theres a lot of 'business' to give the immune systems a good workout!
On a serious note though, one thing you should do is to switch on the water pump and run the hot taps to get all the air out of the hot water tank, otherwise the element could be damaged if its heating fresh air
Phil
PS What's that, your Cali has no hot water system?
Just a quick but horrible thought, if the pipe has split or become disconnected at the tap end you will have been pumping water into the vehicle.....please just open the draws/ doors in the cabinets to check - unlikely but best to check.great thanks will try this evening!
What doesn't kill you makes you stronger.I'd wondered about getting a hoselock flowmeter for filling up as otherwise the only way to tell how much is in there is when it overflows!
Phil
