Ordered! Thank you
These are the ones I use.
I was assuming the one on the left was the style that wouldn't work and the right the ones he already had on the doors. I hope so.Looks to me like the clips on a T6.1 are different to a T6/T5
Hi Deaston,,, just come across this problem trying to get my door card back... ordered the same larger clips don't work... did you find somewhere to get the t6.1 clips? a lot of swearing... and then I look down and see the new speaker is about 0.01 mm away from the window when it's down! start again... grrrrOther way around - the small one on the left is from the 6.1.
Hi DeastonOther way around - the small one on the left is from the 6.1.
Get them from a dealer. They are cheap.Hi Deaston
Did you manage to find any door card clips as I have just had the same thing happen to me on my T6.1. The clips I ordered were also to big?
Thanks for thatGet them from a dealer. They are cheap.
You will be surprised how cheap these are from a dealer. Not worth the hassle of getting the wrong / poorly fitting ones.Thanks for that
