A Brown
Hi all, I'm about to install a half decent ICE set up but after a lot of searches I can't find some information that may help speed things up, so if anyone can help me out that would be very much appreciated, I'll list the questions I have below! I've spent quite a while gathering some good quality kit, and for less than £570 all in with only the active sub second hand, for the specs of each item I think that's very reasonable, I've just got to install it now (or find a very reputable local person who can!)...
The plan:
Retain OE head unit.
Stealth install without having to strip the camper too far (hence using speaker level inputs)
Keep cost to a decent value for money ratio.
Plenty of clean volume up front without being bass heavy.
Spec:
Mosconi Pico 2 mini amp for front, 2x80WRMS (use speaker level input, using auto sense turn on) behind dash.
Focal ISU 200 components in the front OE locations, 8" MDF speaker adaptor rings.
Lots of Deadmat (VLTUK stuff I've used before) and open cell foam for doors.
Polk Auido DB6501 components in the rear, I got the gold ones to match the van (remove the Kenwood 2 way 6.5" already fitted by Autohaus, or perhaps move them to the rear boot area and use the spare channels on the amp).
Pioneer GM-D8604, 4x 100WRMS class D amp for rear (only use 2 channels using rear speaker level inputs, auto sensing so no remote needed, use pre-out on this amp to drive the sub).
Pheonix Gold PG X8150 active slimline sub under RIB bed, or preferably under a front seat if I can get it in.
Rockford Fosgate 4AWG OFC wiring for rear amps and OFC speaker cable.
6mm2 OFC Tri Rated BS6231 53A cable for Pico amp.
Questions!
1. Im going to use two 'mini blade fuse piggy backs/take offs' (15A fuse each from in the front lower fuse panel) and join them to provide the PICO amp with plenty of headroom (30A) - will that cause any CANBUS errors??? Or am I easier just running a fused supply from the main battery under the bonnet?
2. The front components: as there is already a mid and tweeter as standard, where/how do the tweeter/mid speaker wires join??? Is there an easy location within the dash to put the crossovers then retain the OE cables to the new door 8" mid and A pillar tweeter? I am assuming the OE head unit output is wired in parallel to the OE mid/tweeeter, or is it one wire to the mid, then back out the through the door jamb up to the tweeter???
3. I have a decent leisure battery with split charger and solar charger (Autohaus fitted). Can or indeed should I run the rear amps' main power from this or will this cause problems???
4. If I'm not able to use the leisure battery, I am extremely reluctant to pull up the floors to run a 4AWG cable to the rear seats, is there a better way under the van using OE grommets or a simple route through the van without tearing loads out???
Sorry for the essay! Im just keen to make sure things are done perfectly and without damage or a cable in sight!!!
The plan:
Spec:
Questions!
