It's process of elimination with mine as it's only done this since I replaced the rocker cover gasket, and all injector seals so I know mine definitely isn't related to that as I've scowered the web like yourself, I don't get any smoke on cold start, with yours it's a possibility the egr cooler may possibly be leaking coolant into the cylinder just depends on the engine you have, my van is a Ex AA T32 2.0 CXHA 150bhp model bone stock not tampered with.I have bought the same stuff I believe VW Diesel Additive but I put in injector cleaner from another brand beforehand it didn’t do the trick hence why I purchased a new injector. My friend recommended me to swap the injectors around before digging too deep in opening up the engine. As like you mentioned about dark side development injector may even be the issue. The code you had was it as simple as clearing the code off or did you have any work carried out?
Also I do feel as if the misfire remains especially in gear 3 onwards
What makes me think it’s deeper than the injector is have a quick look at this video on YouTube about a T6 misfire.
Will deffo keep you all in the loophole. What bugs me is on a cold start when I make my journey the vehicle smokes like crazy puffing white smoke as I accelerate calms down once warmed up.
If I'm gentle with the throttle it drives like a normal van albeit with slight diesel knock where as driving it normally you can feel the misfire at certain rpm 3rd gear onwards, I'll get to the bottom of it had a few issues with the van but always managed to resolve them, let's see how we get on hopefully my injectors land this week of not it'll be next week's job haha
