Hi, 2019 T6 150 DSG Highline. Purchased as pre reg & professionally converted to camper. On the road from late Nov 2020 with 300 delivery miles only ( registered Aug 2019).
Not used as day van and only done 13500 miles to date. in June 2021 after engine management light on ( orange coil) with only 1800 miles done VW diagnosed Intake manifold runner fault with Actuator valve modification required ( admitted it was known issue but not a recall ). new parts fitted including EGR valve, 1 set of vacuum pipes, air filter, pulsation damper.
since then various UK trips & last year 5000 miles in Europe without issue Ending Sept 2022. van rarely used until late March 2023 for a weekend away. 100miles there saw coil light on again, but cleared after stopping etc. Booked into VW with fault diagnosis of intake manifold jamming/stuck. stating found tpi (no idea what this means) but after carrying out test confirmed manifold flap jamming from soot accumulation & electrical side all ok & vacuum Ok. require new inlet manifold. I took a VW all in policy to provide 2 yr service & warranty but they say soot accumulation is not covered. My argument is with such low mileage, the fact they replaced parts of this before indicates a design or build issue which they should cover. They admit if it was still under manufacturer warranty the inlet manifold would just be replaced. My issue is how is this happening & surely just replacing the manifold does not get to the root cause ( unless the manifold itself was somehow faulty?) & a new one would just eventually suffer with the same issue. Atm I am not driving it as I have no confidence in it but it is needed for planned Europe trips.VW suggestion was for me to try to burn off soot & rely on breakdown cover!!! - unbelievable, or pay nearly £1000 to replace inlet manifold.
Booked into local independent to try to get to bottom of this & might be able to build a case to go back & shout at VW to take some responsibility.
‘Anyone have any similar issues or suggestions to help?
