Interior Handle Screw Size
Simon Finch
Hi all,
The internal handle (spring one above passenger door) has come loose.
Looks like it's the metal bodywork the screw attaches too.
Anyone else had this problem / overcome it?
Can I put a slightly bigger diameter screw it a) will it fit through he handle and b) anyone scone the original screw diameter?
Thanks!
Those screws go into a metal bracket that is riveted onto the body work, you could either change the bracket or fit a couple of rivnuts into it and use bolts instead.IMG_20190223_090918.jpg
I think the thread in the bracket has gone. Not miles out. I’ve ordered some 6mm screws to see it that bites.
It should work shouldn’t it?
