L Lee540 Senior Member T6 Guru 5 Oct 2023 #1 Interior light stays permanently on when switched to door open, when the doors are all closed. engine off or on. There is nothing on the dash to suggest the car thinks a door is still open. Any ideas please? Thanks, Lee
roadtripper 2021 Caravelle Executive Moderator VIP Member T6 Legend 5 Oct 2023 #2 That's a switched ground, so maybe you've got a short to ground in the wiring? Would have to be upstream of the switch.
roadtripper 2021 Caravelle Executive Moderator VIP Member T6 Legend 5 Oct 2023 #3 I guess it's also possible you have a fault in the switch itself if one of the contact wipers has bent or similar.
L Lee540 Senior Member T6 Guru 5 Oct 2023 #4 roadtripper said: I guess it's also possible you have a fault in the switch itself if one of the contact wipers has bent or similar. Click to expand... Yes, poss. it is a bit sticky
