Hi, I think I originally posted this in the wrong place, hence the new thread. I'd be grateful if someone with more knowledge than me on interior lighting could assist please. I am replacing the 2x original load bay lights with LED courtesy lights and a genuine VW step light. I did the step light a while ago, works fine. I then added an LED above the sliding door, on a 3-way rocker switch (to retain the on/off/door functionality). See badly drawing wiring diagram of my mods, attached. When I open the door, the LED comes on at the expected brightness. Last night when I fitted it, it came on for around 30 secs, then dimmed-off, along with the step light and cab lights. When I switched it to 'on' it came on but very very dim, unless I did this within 30 seconds of opening the door, whereby it was very bright. I also found that if I turned it 'on' (dim) then briefly touched the original filament bulb across the connections to the new LED, its brightness increased dramatically. Might be worth noting that at this point, the engine battery was pretty low and I had not put the key in the ignition at any point during the installation. May also be worth noting that I had to use the negative from the chassis, rather than the loom, due to inability to route all of the cables through pop-top surround. I thought this might be a resistance-sensing thing...... however.......
Next day......
I drove the van to work (45mins) and found that after this, the LED came on at the expected brightness, in both switch positions. The timer delay however had now increased to around 10 minutes, until the lights all dimmed to off (which from reading this forum seems normal) so all appears to be ok....
Any ideas?!
UPDATE: I originally wrote this 5 days ago and nothing has changed since, so all working fine but curious as to know what changed overnight, incase there is a nasty surprise lurking still......
I plan to fit 2 of the same new LED lights by the tailgate next, on one 3-way switch.
Assistance greatly appreciated!!
Jim
P.S. I know some people have had issues with the LED glowing when 'off' when making similar modifications, but I do not have this issue currently.
Next day......
Any ideas?!
Jim
