Hi I did a bit of a drive on Saturday around 700 miles and this morning another 250 on the way home. After around 10 miles I had the flashing yellow coil indicator lamp that the manual refers to as an engine management fault . I then realised the van had lost power, had become spongey and lacked acceleration .
I drove home regardless as it was only really effecting acceleration I could still do 70 mph once it got moving . But was having difficulty on hills and pulling away at speed.
I could see the acceleration was never reaching higher than 2000 revs .
My foot down and not much happening !
(I've had this light come on before during some very wet weather but didn’t notice a drop in the ability to accelerate .)
anyhow close to home I stopped ,did a little shopping and upon restarting the van ..the fault had vanished and the engine was back to normal .. at this point I realised if I had just stopped when the light first came on and the noticeable lack of acceleration started I could have probably avoided the 240 miles of limping home !
( could this have damaged my engine ? I guess not as it was being limited )
so anyone have an idea what the hell is happening ? Obviously a fault is detected but why would switching the engine off and then restarting clear the issue ?
( a bit like restarting a computer ? An unknown bug )
I guess it detects a temporary fault and then limits the acceleration until the engine is restarted .. at which point it no longer detects an error and allows the engine to operate as normal .
If this is the case does anyone know a likely cause for this intermittent and annoying error ?
