So, I’m just on my way back to the service centre to collect my van again!
After the centre replaced the crank sensor ( third visit, first visit fuel pressure sensor - second timing belt and tensioner ) the problem worsened dramatically.
The van went back in on Friday and thankfully the technician managed to get the the computer on it and they witnessed the fault live for the first time.
Turns out they’ve found the fuel pump relay has a “dodgy pin” and was fitted that way when the van was built, hence the intermittent nature of the fault.
I’ve persevered with this since it was a couple of months old because apart from this tiresome gremlin I absolutely love it.
So hopefully this time it’s fixed
Start up fault
Hi again, I'm trying to record my van when in fault with my new VCDS. I think the attached might show the fault? The problem is the fault doesn't present every start up. Once when I was trying to record it the VCDS just displayed n/a in every column. I've ticked the boxes that delmassive...
www.t6forum.com
