Intermittent Vibration at idle and set off
Mills1122
Evening all , looking for advice .. I have a 21reg t6.1 150 highline dsg , been away this weekend in the van and when we set off home I noticed an intermittent vibration directly under drivers footwell.
once moving, it disappears but comes back at idle and when I move away forwards and in reverse.
It comes and goes at idle and when steering wheel is moved when parked so was wondering if it’s power steering? The only thing I did out of the norm on Saturday was put the towing eye on the front as I thought I was going to need a little tow in the snow but in the end I managed and never towed the van.
I’ve checked for loose plastic trims front and underneath and I can’t find anything, no loose exhaust mounts either. Any thoughts guys ?? Thanks in advance
Welcome to the forum. My view isn't an expert view, just a keen DIYer, so please take it as a non expert view.
You don''t say how many miles your T6 has done, but the symptoms could be early symptoms of DMF failure.
This is not a diagnosis, that's not possible on the information available.
Hi ! Thankyou for the reply , it’s done 55k , mostly motorway
I'd have thought that DMF failure is just one possibility, you need a proper diagnosis from a good mechanic. On this forum we've seen DMF failure at much lower mileage, but as I say, there are other possible causes.
plan tomorrow is to get it booked in for diagnosing .. just looking for any thoughts on here that’s all .. difficult to diagnose without hearing it but any ideas at the minute are appreciated
