Internal 3-pin plugs - when should these work?
Redvanman
I have a T6 semi converted. I have two 12v 6amp points at the rear of the passenger seats base. They both work fine. I have two corresponding 3 point plug sockets on the base of the drivers seat - they however do not seem to be working. I’m new to the camper scene - will the plugs only work if the van is hooked up or should they work without being at an electric hook up?? Cheers
Unless you are running an inverter they are only connected when hooked up.
