Thats a compressor fridge (power draw looks low, so should be ok. but never seen one in the wild) :
Product description
The Kolner 2-in 1-Fridge and Freezer comes with a unique Smart Fridge App making it easier to have full temperature control at the tip of your fingers. Simply download the app on Google Play or the App Store.
It's never been easier to keep your food fresher, wine, cheese and other beverages chilled, and your sweet delights and ice-cream frozen if required. This is the perfect must have for a fun family adventure or getaway.
Our unbeatable unit comes with a powerful compressor and electronic control module to ensure you and your family enjoy the cooler things in life while enjoying the sunshine, camping and other outdoor activities.
Using the Fridge/Freezer is a breeze. Just plug into any 12V or 24V DC power outlet or 240V power point for it to start working its cooling prowess.
Set the required temperature, between -20C and 20C, via the LCD control panel and leave the hard work to the compressor to cool the temperature accordingly.
Also, the high-density polyurethane insulating layer further helps to keep temperatures consistent without losing the cold to the surroundings.
FEATURES:
- Smart Fridge App
- Capacity - 40L
- Can be connected to 12V, 24V or 240V
- Suitable for home and car use
- Draw bar handle and wheels
- Rugged and anti-vibration construction
- Accurate temperature control
- Low power draw: 45W or 0.2 kw.h/24hrs
- Refrigerant: R134a - 32g
- Foam vesicant: C5H10/C - Pentane
- DC Power Cable
- AC Adapter
- LCD Panel
- USB Outlet
- Weight: 12.5kg
- Dimensions: 58(W) x 37(D) x 47.5(H)cm
- Drain Plug
CONTENTS:
