Jackery power stations
which one you looking at? (there are a few models)
The Jackery can be seen on YouTube, mainly in the States.
The Explorer 1000....do AP do one that size? Reviews of the Jackery seem positive.
ALLPOWERS do the 372wh unit - Awesome 3-in-1 Battery Bank - How I done It -
they also have a 666wh unit,
there is a larger version in the pipeline too.
£1095 for 1002wh
Jackery Portable Power Station Explorer 1000, 1002Wh Solar Generator (Solar Panel Optional) with 230V/1000W AC Outlet, Solar Mobile Lithium Battery Pack for Home Emergency Power,Outdoor RV Camping​
Specifications:
Portable Power Station Explore1000 Battery Capacity: 1002Wh (46.4Ah, 21.6V)
2*AC Output: 2*230V, 1000W (2000W peak)
Car Port: DC 12V, 10A
4*USB Outputs: 2*USB-C ports with PD, 1*USB-A port, 1*quick charge 3.0 port
Input: 8mm DC, 12V~30V
Dimensions: 13.1*9.2*11.1 in
Weight: 22.04lbs
Note:
For power saving, Explorer 1000 portable power station will be turned off automatically in 12 hours when being drawn under 10W power.
Due to the big size of Jackery Power Stations & Solar Panels,PO Box address can not be accepted.
Package:
1*Solar Generator Jackery Explorer 1000 Portable Power Station (1002Wh Portable Power Station)
1*AC Adapter
1*Car Charger Cable
1*SolarSaga Y Parallel Cable
1*User Guide
FAQ
Q1: How to know the working times for my device? Why does the duration of some devices deviate from the actual usage data?
A: Working time = 1002Wh* 0.85 / operating power of your device. The duration of our equipment is based on laboratory data, and the duration of specific equipment usage may vary.
Q2: Can the Explorer 1000 be charged while using?
A: Yes, Explorer 1000 supports pass-through charging. But we don't suggest, it will cause damage to battery life.
Q3: What devices can Explorer 1000 power?
A: Please note that the AC output port can only charge/power devices that operate at less than total 1000 Watt.
Q4: Does Explorer 1000 include a built-in MPPT controller?
A: All Jackery power stations have a built-in MPPT controller.
more info:
looks like Jackery are reselling via Amazon in the UK
lets see what Will P has to say . .
have a look at the ECOFLOW Range:
1260wh @ £1299 = £1.03 per wh
gotch, on paper any device that can supply 1200w+ "should" be able to run it.
but i depends on how the internal batteries will have any voltdrop that will cause a low battery alarm. - when the machine is on.
or any surge rating . . . ie 1800w surge, but for how long?
on paper the ECOFLOW DELTA should run it fine . .
• 1260Wh Capacity & 1800W Pure Sine wave AC Power Surge to 3300W
unfortunatly the only way be be 100% sure is to try a real worl test . . . . ie - plug it in a try.
I don't use a coffee machine in the camper as prefer to make it old school. What I do use is a Remoska cooker
Link: Standard Remoska Electric Cooker with Glass Lid 2L in microwaves, ovens and hobs at Lakeland
The above is the new model - ours is 6 years old and still working a treat. We cook baked potato's in it using ALLPOWERS 666wh and get about 1hr30 however using solar panel get around 2hrsish. We also cook pie's chips etc in the little cooker and works great on the ALLPOWERS 666wh.
The best thing is by tea time the solar has charged (4/5/6hrs depending on the sun) up the "brick" ready for the evening. Love it as no need to pay for EHC on sites if we use them.
yeh . . . , heating water is not the most efficient use of battery power unfortunately.
it can be done but its very inefficient.
Gas is the way to go, for efficiency.
when camping we use a single gas burner and a MOKA POT.
we have this one . .
and one othe these . .
I had a little solar test run today with my PowerOak PS6S / PowerOak S120W folding solar panel. I was amazed to see peak charging at 115W and constantly at +105W in the sun. Now wishing I'd bought bigger errr.
If you combine all your units how many Wh do you have ?!!!!
if were talking about Lithium Wh . . . . then about 8832Wh that i can put my hands on now and deploy in one form or another.
4-5Hrs to recharge it fully by a 120W solar panel
  • G-mark Award 2019 Power Station: High capacity 500Wh/300W (Peak 450W) rechargeable Lithium solar generator, 500Wh (45Ah, 11.1V) with 2 * 230V AC-Outlet (pure sine-wave) can charge small appliances (Max.300W) such as smartphones 36 times, laptops (45W) 9 times, Gopro 80 times, drone, mini projector, mini car fridge and others. The PowerOak PS6S portable power station is an ideal emergency power backup for RV outdoors, camping, natural disaster or other power outage situations.
  • AC / Solar / Car Recharge Options: 6-7Hrs to full recharge the power station from a wall Outlet (90W AC adapter included); 4-5Hrs to recharge it fully by a 120W solar panel (not included); DC12V and DC24V car outlet can charge PowerOak PS6S to 100%. Foldable handle design is perfect for outdoor adventure and camping.
  • Multiple charging available: Wireless Charging / PD 45W USB-C / DC12V / USB 5V / 230V. Multiple charging options can make your life more convenient. PD 45W available to charge all USB-C PD devices. 4 x USB ports to charge phones, tablets, cameras, etc. 12V available to charge mini refrigerator for example due to the regulated DC12V. 230V to charge everything up to 300W.
  • Safety guaranteed: Soft glue design & superior flame retardant material. We use auto-level battery cell with high discharge rate, low heat dissipation and more than 1.000 life cycle. LED lighting on the back of the unit (including SOS Function) is especially practical for emergency situations. It's noise-free, zero emission, eco-friendly. Battery management system (BMS) enables voltage/current control, temperature control and more advanced safety functions.
  • What You Get: 1*PowerOak PS6S solar portable power station (500Wh/300W, 11.6*7.5*7.7inch, 13.6lbs / 295.5*1914*195mm, 6.2Kg), 1*AC adapter & cable, 1*cigarette lighter cable (cigarette port to DC7909 connector male), 1*MC4 cable (MC4 connector to DC 7909 male), 1*USB Type-C cable, 1*carry bag, 1*user manual, 1*warranty card.
