We had one fitted by absolut5 in Amesbury, the difference in the sound and vision is miles better then the standard audio unit supplied with the van. I haven’t got round to linking it with Apple play yet. Dvd sounds as if it is being shown in a cinema.
Im thinking about swapping the headunit in my van because apple carplay isnt enabled. Although I think I could buy a code from VW to enable it?
Also the limit on 4 digits in the postcode for the sat nav really bugs me as well.
With the Kenwood will everything in the info part of the dash in the bottom pic still work as before (inc the sat nav directions?)
Also what else do I need to but in addition to the Kenwood unit itself to make it fit and work? I have OEM reversing camera as well.
We can supply everthing needed for seamless integration
Flush fit facia
Kenwood interface for parking sensors,mfd and MFSW
USB retention kit
Dab aerial adapter
Fm aerial adapter
It will retain the parking sensor graphics, vol up/down station up/down answer and hang up, station name, track name and Garmin nav directions on the MFD (needs coding) if it’s not a nav unit from factory
The only thing you lose is the call history on the mfd
But you gain so much more, super fast nav, Superb HD motorised reverse tilt screen, Apple CarPlay, Android Auto, cd/dvd, sd, twin usb, Bluetooth and the ability to control the optional dash camera
Hi Absolut5,
Would you please PM me an idea of cost of the Kenwood and the necessary adaptors to use the MFSW and display the parking sensor graphics and original aerials, also the USB retention.
Also, does it use the original microphone for the phone? Where do you mount the GPS aerial please?
Are you able to code in the MFD to display the nav directions?
Thanks for your assistance.
Pete.
Hi i am after a quote for the supply and fitting of the new Kenwood DNX 9180dabs.
I need everything needed for seamless integration
Flush fit facia
USB retention kit
Dab aerial adapter
Fm aerial adapter
I have a 17 plate hipline thanks jason
Flush fit facia
USB retention kit
Dab aerial adapter
Fm aerial adapter
