I've got a Kenwood DNX9180DABS head unit in the van, last week about 45 minutes into a drive there was a pop from the speakers and the headunit went dead. At first I thought it was a blown fuse but then it powered back up by itself 30 seconds later. It went straight to the security-code screen (as if it had been reset I suppose). Then it ran fine again for about 5 minutes before going pop, again 30 seconds later it came back to life. 5 minutes after that I was back home so I don't know if it would have happened again.
The unit is only six weeks old, supplied and fitted by Absolut5. It's been fine until this happened. The firmware on the unit is fully up-to-date.
I asked Jason at Absolut5 what he thought, but he's not seen this issue before and has no ideas. He suggested I call the repair centre, which I've done and their suggestion is a loose connection on the permanent 12V supply. I'm going to try and get the unit out at the weekend and check this, but frankly it seems unlikely that I'm going to find anything. The 12V supply has been fine for months to the factory headunit, and the new headunit uses proper Kenwood-VW connector (so no dodgy scotchlocks or anything).
Anyone got any other ideas before I look at returning the unit for replacement? Cheers.
