Howdooo
got these in today...mint....got all my reinforcement brackets in full flow...
only thing that throws me....the rear most outer singles... some are not alongside the chassis rails and i can not see what official bracket should be used.
these i know are norm in row 2 but i have a pod behind the drivers seat etc and a knackered back means the singles i can just get out if need be..
the factory floor divets are there...all in proper and correct...the front row of brackets on row 3 is perfect...alongside the chassis rails...
then the rear most ones get tricky on the outer two singles....im t32 with ind rear susp...
some are not alongside a chassis rail...
use my own reinforce brackets?
looked at the tps breakdown....
any else had similar?
many thanks if can help.
chris
chris
