Labocosmetica 2PH system
spooks007
I applied a coat of can coat over the transporter on October as a temporary measure until the spring where I can apply a full coating.
Over the past few washes I've noticed the water starting to sheet on the lower panels around the wheel arches.
With the recent bad weather and salty roads I decided to give the Labocosmetica 2PH system ago
Primus 2.0
Purifica
Fair play both products have bought the coating back to life.
Primus 2.0 did en epic job bringing the coating back and tbh that was good enough on its own but decided to use both systems
Method
Primus 2.0 10:1 spray over lower panel in an IK sprayer 1.5L
Used remaining product in a foam gun and foamed entire van.
Let dwelling and rinsed off
Wash bucket with a ratio of 100:1
Washed van with mit and rinsed off .
Purifica 10:1 in an IK sprayer 1.5L
Let it dwelling for a while then just Used a different wash mit for contact wash using the foam on the van
Water beading restored epic products and has completely restored the coating.
If you thing your coating is dead or not performing give this a go .
When I had my van Siramik coated 7 years ago, the detailer said to use bog standard caustic TFR when washing. I have done, & the water is still beading off the van after 7 years.
