A big thing to look at is if the base of the flooring is not MDF, this product is heavy, even the moisture resistant versions are poor at not swelling over time.
They are quite restrictive on how you can clean it, id personally look else where.
I've had it in a few houses I've brought, the laminate is quite tough, but the joins to the sub structure are the weak part.
I've also currently trying out a timber veneered engineered floor on plywood in an apartment and that has its issues as well, being replaced again in the near future.
You can't go wrong with a wood grained commercial Lino/Vinyl, easy to lay, easy to clean.
