Sold LED DRL bulb - suits H7 headlight
Adam_T6
Suits H7 headlight - check the photo and compare if you’re unsure.
Osram DRL LED, I ordered from two suppliers as one didn’t turn up and I’m impatient!
£20 posted.
19024FC4-D590-41B7-BF66-2F6438C9D8CA.jpeg86634779-1478-463D-A447-593CDB302053.jpeg275996B3-ED43-48C5-9CD8-C3C648771B23.jpeg
Do you know what the wattage of these are please? I’ve got some osram LEDs In my H7 but these look brighter than mine.
I’m not sure to be honest, although these have since put the bulb warning on.
Thanks mate, I wonder whether they’re the same lights but one is a newer version of the other. I don’t generally get the bulb warning unless the battery voltage has dropped a bit over a week or so. Once it’s been started and then started again, I don’t get a bulb warning.
These are the ones I have.
I’ve tried to order that style a few times from suppliers but only get the version I have above, from what I’ve been told they’ve been superseded.
Anyway to remove the bulb warning permanently? I have DRL in the grills and the original main DRL look so yellow and crappy
Did anyone successfully find a pair of LED DRL W21W bulbs that work without the warning light (canbus error free) please?
I’m 90% sure I ended with these:
They’ve been in 3 months with no issues, I’ll double check later.
I Also have the twenty20 LEDs in my h4 T5.1 headlights. No bulb warnings.
