Hi all
I have installed a on/off/on rocker and led strip to replace the rear lights.
All conceptions from the original wires.
positive to the controller. Negatives door/permenant to either side of the switch and common to the controller.
All working as it should with the engine off.
Start the engine and it seems things go amiss? On opening when the courtesy lights come on, they revert to 70’w disco mode. Flashing.
It then looses its colour setting. (And the white isn’t white anyway.
Here is the simple Stuff I bought.
They are the best. I may change for a pure white set. As tgey aren't very white. And it's little dotty.
Anyway. Any suggestions as to why I'm having issues please? Or should I just add a mosfet board?
Thank you
Thank you
