Leisure battery and 3 pin 240v plug
ChrisM1973
Hi, I have a T6 (may 2016 - so may actually be a 5.1 - that's how much I'm a newbie to all this) and I have a question for the incredible hive mind out there:
Where can I get the best leisure battery kit (including the battery) as well as the loom/wiring to put one double 240v three pin socket in?
I can see 'kits' online with the conversion, but that don't contain the battery itself. Or should I buy it separately. Huge thanks for any info!
What does the front of the van look like? you'll be able to know if its a T6 or a T5.1 from that.
Regarding leisure battery etc, you can get them from @travelvolts he will also supply all your needs for distribution and protection. If its a T5.1 you can get away with a VSR, if its a T6 you'll need a DC-DC charger as the alternator is 'clever'.
Drop Martin a pm and he will fix you up.
I would second that, speak to @travelvolts
He has kits and parts available on his website but if you need something specific/non standard im sure he will help you out
