Just considering my next build to the new T6
I've previously installed a split charger & a couple of leisure batt's into my T4 to power led lights, fridge & gas blower heater etc, so I know the crack.
Anyone on here build their campers using the Ecoflow Delta as the power source for everything? If so, what's the Pro's & Con's please ??
Regards Paul, Shropshire
Check the number of cycles the system can do. It strikes me as not being all that many -800 I think. Great looking unit, though.
Anyone got any advice on my new build that's starting soon to my new T6
I've previously installed a split charge & battery system into my T4, so I've experience...
Ecoflow Delta power pack is looking interesting this time instead any thoughts out there about using this rechargeable battery ?
Have a quick look here...
You need a dc-dc charger for a T6.
Look at the Portable Power Pack sections.
And the EcoFlow section.
And solar if you are interested.
Also, I think all but the 'Pro' models use NCM chemistry, whereas the 'Pro' uses LiFePO4.
I bought an AllPowers battery bank instead of going for a leisure battery, dc-dc charger and inverter.
It provides 12v DC and 240v AC so I can run some USB sockets, 240v sockets, 12v LED lights, CCTV camera and trickle charges my Wi-Fi hotspot.
I still need to hook up the trickle charge from the van ignition feed and also thinking of a small solar panel to also trickle charge it. I also need to build some sort of enclosure for it under my Kombi bench seat.
The unit is quick release so I can remove it from the van by disconnecting 3 plugs.
More info here Bloated Black Kombi Build - #vanlife2.0
I had a full hook up and smarty charge with solar in my first van. Now in van 2 I just have the Ecoflow River pro with solar. I can move it in and out the van, use it outside, use it where ever I want. I wouldn’t go back to a full wired system personally if not in a full conversion van.
Dellmassive’s "How I Done It" blogs.
-- Dellmassive`s -- "How I Done It" -- thread -- ************************************************** Dellmassive`s -- "how I Done It" -- Thread ************************************************** Kit List And Stuff -- How I Done It & What I Use --...
www.t6forum.com
Cheers for the infoHave a quick look here...
-- Dellmassive`s -- "How I Done It" -- thread -- ************************************************** Dellmassive`s -- "how I Done It" -- Thread ************************************************** Kit List And Stuff -- How I Done It & What I Use --...www.t6forum.com
Depends which model. The 'Pro' is rated at 3500 cycles to 80% SoH, though it is ruddy expensive (~£3.5k).Check the number of cycles the system can do. It strikes me as not being all that many -800 I think. Great looking unit, though.
Thanks for the infoI bought an AllPowers battery bank instead of going for a leisure battery, dc-dc charger and inverter.
