I am starting a thread here to document my leisure electrics install in my new van as I have learned so much from other people's threads here.
This is my second van conversion, that last one was a T5 and was a lot more simple as I was located in the UK with so many suppliers and access to basic VSR kits. This time I have a T6 in Australia and everything is just a little bit harder to source. I am not planning on doing such long trips in this van as I did in Europe however, so I have not added a shore charge circuit.
As the van is still in build stage, with insulation and wall linings going in, I am currently just preparing for my electrical install. I have ordered most of the items listed in the diagram below, but as nothing has been installed yet I still have time to make changes if anyone has any tips or suggestions.
I will add an important disclaimer - I am a complete amateur at this, I understand basic electric principles but I have a lot to learn. I am sharing my experience and lessons for others to learn from, but do not assume that I know better than you!
Cable
AWG 6 & 8 - Battery / Starter | Tycab Australia
2mm & 4mm* - Twin Sheath Two Core Flat | Tycab Australia
*Some industry standard apparently, not the cable area!
High Amp Side
Cable
High Amp Side
- Renogy 30A DC2DC Charger with MPPT - DCC30S 12V 30A DC to DC Battery Charger with MPPT
- Bluetooth Module for the charger - BT-2 Bluetooth Module for Renogy Products w/ RS485 Port
- 500A Battery Monitor - Renogy 500A Battery Monitor with Shunt
- 100A Smart Battery Protect - Smart BatteryProtect - Victron Energy
- Note that this doubles as an isolator, either via the app (Bluetooth) or a switch on the remote port
- 100A Bus Bar - Common 100A Mini BusBar - 4 Gang - Blue Sea Systems
- Fuse box with negative rail (x2) - 19Pcs 6 Way Auto Blade Fuse Box Holder Block Panel 32V Car Power Distribution AU | eBay
- Victron Phoenix 12/375 300W inverter - Phoenix Inverter VE.Direct - Victron Energy
- Fridge - TBC
- Touch dimmable recessed down lights - 3W Touch Dimmable 69mm Recessed LED Down Light
- Strip Lights - Waterproof Warm White 12V 5M 3528 SMD 300 Leds LED Strip Lights Car Boat Caravan | eBay
- Pivot Light - 12V LED LIGHT 12" 24 BRIGHT WHITE LED SWIVEL STRIP LAMP | eBay
- 6A 12v voltage regulator - https://ebay.us/Idxlja
- MOSFET switch - https://ebay.us/GnjoVR
- 12V PWM controller - https://ebay.us/YF4MLV
- 80mm fan (x4) - https://www.jaycar.com.au/ip55-80mm-12v-dc-ball-bearing-fan/p/YX2523
